Engine Performance problem
1994 Chevy Blazer V8 Four Wheel Drive Automatic
hello,engine will not start,i put wires,plugs,cap,rotor,exhaust maifold bolts,coolant tempurature switch,serpentine belt,idler pulley,distibutor,valve cover gaskets,tightened rocker arms down 1 1/4 turns.i brought up number one cylinder and did the number 1 cylinder side first and cranked it 360 degrees and brought number 4 up and tightened down the number 2 side.and still it will not start.but the only thing is when i started working on it the guy before me forgot to mark where the distibutor was.
Jul 18, 2008 at 8:19 AM
