TTOSTUDENT
My boyfriend had unplugged the abs on our blazer and put all new as he calls them regular brakes on the blazer but when the vehicle is running and you step on the pedal it goes to the floor before finally stopping. Could you please, tell me what the problem could be and what I could do to fix it? It would be very appreciated, thanks.
Sep 12, 2009 at 8:02 AM
MERLIN2021
  • 17,250 POSTS
Inspect for fluid leaks as a first step, remove the drums in the rear or calipers look under the dust boots of the wheel cylinders and or calipers, if fluid is dripping out there is a problem, or it could be if they are drum in back, he either install them wrong, or didnt adjust them. Tell me if you have drum or disc in the rear and we can dig deeper.
Mar 19, 2021 at 5:25 AM
