1994 Chevy Blazer
CHARLOTTE.MARICLE
Engine Performance problem
1994 Chevy Blazer 6 cyl Two Wheel Drive Automatic
I have had to put 11 fuel pumps. It has the 4.3 vortec center port ind, and I get 68 lbs. of pressure at the engin but it keeps burning pumps.
Feb 7, 2010 at 5:18 AM
JDL
  • 16,098 POSTS
hi, were the pumps all new? Did you try a different brand? Are you TBI or spider fuel system? That pressure you listed is too high or TBI, maybe a little high for the spider system. That fuel spec you listed, is that key on engine off or idling? how long since a tune-up?
I'd have to check actual voltage reading and ground for the pump. I'd check amp draw, also.
Feb 7, 2010 at 5:34 AM
