Engine Performance problem
1994 Chevy Blazer 6 cyl Two Wheel Drive Automatic
I have had to put 11 fuel pumps. It has the 4.3 vortec center port ind, and I get 68 lbs. Of pressure at the engin but it keeps burning pumps.
Sunday, February 7th, 2010 AT 1:18 PM
JDL
MECHANIC
Hi, were the pumps all new? Did you try a different brand? Are you TBI or spider fuel system? That pressure you listed is too high or TBI, maybe a little high for the spider system. That fuel spec you listed, is that key on engine off or idling? How long since a tune-up?
I'd have to check actual voltage reading and ground for the pump. I'd check amp draw, also.
