1994 Blazer severe miss low speed high speed fine
RLK
Hi I have a 1994 Chevrolet Blazer with a 3 Vortec engine. It reportedly has had new wires and plugs. O2 Sensor and fuel filter recently.
The problem is a severe low speed miss or miss under load. It seems to idle ok. At speeds above 50 you can punch it and it accelerates fine with no noticeable miss
Any suggestions appreciated
Sep 13, 2007 at 9:44 AM
CBOB01
I am not an expert, but I would check the fuel line do a pressure test on the fuel line, to check the fuel pump then check the mass oxygen sensor.
Oct 9, 2007 at 6:05 AM
