1993 Chevy Blazer strong gas oder
ISABELLA_DIANA
1993 Chevy Blazer 4 cyl Four Wheel Drive Automatic
the blazer acts like its running out of gas after putting it into drive, there is a strong gas oder. the diagnost said code 35, but i put a new automatic idle senser in.
Sep 18, 2010 at 10:06 AM
  • 75,988 POSTS
Check your fuel pressure if is within specs-if not could be the fuel pressure regulator or the fuel lines are leaking underneath the upper plenum also check the charcoal canister if its saturated with fuel and for any visible leaks
Sep 18, 2010 at 8:59 PM
