1993 Chevy Blazer Steering Pump Hose change
177,000 MILES • 6 CYL • 4WD • AUTOMATIC
AFR58
The main steering pump has a large steel/rubber/steel hose that leads from the bottome of the steering pump to the steering box. How do you reach the connection on the bottom of the pump?
Feb 25, 2009 at 8:01 AM
  • 110,248 POSTS
You need to remove the pump from it's mounts and swing it around.
Feb 26, 2009 at 3:17 AM
