recently ive had a no start problem with my 1993 chevy s10 blazer. i recently (last week) had a similar problem so i replaced the spark plugs, spark plug wires, dist. cap, rotor, and also the coil and ignition module. the problem was fine for a week i drove it approximately 500 miles without missing a beat. this morning it was like -2 out so i decided to fire it up before work and then it shut off and would not restart, it would crank fine, no ck engine light or any other noticable problems. so i tried starting it once again and it turned over about 4 times and fired right up. so i figured problem was solved. being too cold? i was then in my house and it was running for a few minutes and once again it shut down. it cranks but will not fire up. i added a few different types of treatment to the gas also. I believe the problem may be spark related, but i have no idea where to begin my troubleshooting>.???
Feb 11, 2008 at 10:32 AM
