1993 Chevy Blazer engine replacement
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRIS KEZIAH
I would like to know if a 2003 6 cyl Chevy S10 pick up engine will go into a 1993 Chevy Blazer also a 6 cyl ?
if so will it mount the same or is there anything that I need to be aware of ?
Sep 18, 2010 at 11:54 AM
MADMIKE1735
  • 951 POSTS
the block will bolt right up to your existing mounts, but you will come across some problems with the sensors in the new block, and the plugs in your factory harness.... i recommend getting a good used engine that will fit your model... i believe it should be a 4.3 vin W CPI... save yourself some time in the longrun by replacing the headgaskets, lower intake gaskets, oil pan gasket, etc because its 250$ for the gasket set, and maybe 2 hrs extra while the engine is out.... its less headaches down the road.
Sep 24, 2010 at 12:19 PM
