1993 Chevy Blazer engine coolent hose
KATMAN07
Engine Cooling problem
1993 Chevy Blazer 6 cyl Four Wheel Drive Automatic
hi,
i have a leak in my engine coolent hose on my 93 chevy blazer, i was told by a mechanic that i have to replace the hose wit a new one. however ive been trying to take out the hose but i have been unsuccesful, is there a specific way in which the engine coolent hose can be taken out? any help will be greatly appreciated.
Jun 16, 2009 at 2:49 AM
  • 110,248 POSTS
Which hose is being replaced, a radiator hose, heater hose...?
Jun 18, 2009 at 4:59 AM
KATMAN07
My dad doesn't speak good enligsh and I'm not good with cars but he believes its called an egnine coolent hose or engine transmission coolent hose. That is attached to the oil filter. Goes from egine to oil I just wanna know how to take it out bcs gm is askin for over 500 dollars any help is appreciated
Jun 19, 2009 at 9:14 AM
  • 110,248 POSTS
Is it the hose that goes to the oil filter on the inner fender (driver's side front)? If so, the is an engine oil cooler line. It will either have a quick connect where you push down on it and remove a retaining clip, or it will bolt on. There will be an O-ring there that usually goes bad and causes a leak.
LEt me know if this is the item you are looking at. If not, can you take a picture of it and upload it for me. IT's hard when one isn't there to see and I want to make sure I am correct on the part you have mentioned.
Jun 19, 2009 at 9:59 AM
KATMAN07
yes it is the hose that goes to the oil filter on the inner fender and its bolted on, how can it be removed?
Jun 19, 2009 at 10:34 AM
  • 110,248 POSTS
Let me know if you run into trouble.
Jun 19, 2009 at 10:48 AM
KATMAN07
yes it is what ur telling me and yes it is bolted but im struggling taking the bolts out, how can this be removed?
Jun 19, 2009 at 10:59 AM
  • 110,248 POSTS
The only thing you can do is unbolt it. Would it make things easier if you removed it from the inner fender?
Jun 19, 2009 at 1:22 PM
