1993 Chevrolet Blazer S10 4.3L Vortex 2WD. The fuel is not spraying through the injectors. I have replace it with a new fuel pump system, a new fuel injector system, new distributor system, and computer all brand new. However I cant get the fuel from the pump to the injectors. and the fuel pressure reading is at 15lbs.
What could prevent this? Also, Does the computer new to be programmed to the car? Is there a relay/sensor that would prevent the fuel injectors from opening up?
Apr 18, 2010 at 4:51 PM
