1993 Chevy Blazer 4 wheel drive does not work
207,000 MILES • V8 • 4WD • AUTOMATIC
FREAKUNDERBLOOD
My four wheel drive does not work. It worked one day, but the next it wouldn't and still does not work? What can I do to maybe fix the problem pretty easily?
Nov 18, 2009 at 1:57 AM
BIGJIM79
  • 239 POSTS
These 4wd are pain. The prob could be from the switch, motor, position sensor, computer prob. best start is to check fuses and relays. From there go to swtches and so on . I hope this helps. If you like the way we work for you please donate and vote
Dec 5, 2009 at 6:27 PM
TUNEUP1200
  • 18 POSTS
If your 4WD is the push-button type (if not, don't read)
You will need: small screwdriver, q-tips, and rubbing alcohol.
Pop out the 4WD button assembly from the dash. Unplug the the two wire connectors. Hold the button assembly in your hand face down. make sure you are in a place that, if you were to drop something small you can find it easily, but lets just hope you're careful. With a small screwdriver, pry the back of the assembly from the front....remember to keep the face down in your hands at all times. You see those blue boots with metal contacts on them? These are the things that will fall out easily. Take your time, remember where these boots are located they will pop out easily. In fact , have someone handy with a camera to take a picture of it before going further. Now with a q-tip dipped in alcohol gently clean the metal contacts in the blue boots. Then, with the q-tip and alcohol, clean the whole face of the board that the blue boots come in contact with, paying close attention to the white circle patterns on the board. They may not look dirty but it doesnt take much to make this assembly act nutty. When done cleaning and parts a fully dry, re-assemble and give it a try.
Dec 10, 2009 at 3:09 AM
