1993 Chevy Blazer 3/4 ton full size blazer
170,000 MILES • V8 • 4WD • AUTOMATIC
JEEPSHAUN
Every gear is drive,park,neutral,reverse doesnt matter it wants to go forward,we took off the pan the Linkage seems to be working fine its nice and tight and we put a new filter in it so can you help us ? Looking forward to hearing from you guys thanks for your time.
Mar 18, 2010 at 4:36 PM
  • 110,248 POSTS
Based on your description, it sounds like one of the retaining clips in a clutch pack has broken allowing the clutch to stay engaged. To check that, the trans needs torn down.
Mar 20, 2010 at 6:09 PM
JEEPSHAUN
What would cause that to happen?and how hard is that to get to and fix and thanks for your info
Mar 21, 2010 at 10:50 AM
  • 110,248 POSTS
If I am correct, the trans needs disassembled to access the clutch pack. It is an involved job.
Mar 21, 2010 at 2:16 PM
