1993 Chevy Blazer
JENCLEM723
  • 1993 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 189,000 MILES
My 93 chevy blazer shakes when coming to a stop and it sometimes stops hard and accelerates on its own.
Sunday, April 27th, 2008 AT 8:44 AM
MERLIN2021
  • 17,250 POSTS
You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If your Service engine light is on check this way.
https://www.2carpros.com/forum/automotive_pictures/62217_95_OlderGM_10.jpg
Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here. This connector is right under the middle of the dash..
Sunday, April 27th, 2008 AT 8:48 AM
