1992 Chevy s-10 blazer before i pulled it apart
LEOGALLANT
  • 10 POSTS
Noises problem
1992 Chevy Blazer 6 cyl Two Wheel Drive Manual
the noise started when i was going bout thirty, then i hit the breaks hard and came to a stop. when i reved the motor there was a clinking noise that sounded like it was under the hood.it went away very quick so i ignored it. what could be breaking now.
Jun 17, 2008 at 1:58 PM
DOCHAGERTY
  • 9,606 POSTS
Noises are very difficult to diagnose from cyberspace. You state it made a clicking noise and then it stopped, was the clicking related to engine RPM or was it speed related or neither. Has it come back? Can you tell where it emanates from?
Jun 17, 2008 at 2:15 PM
LEOGALLANT
  • 10 POSTS
the noise happened everytime i had to come to a full stop quickly. and i did sound like it is comming from the motor. and when i reved it up higher or started moving it would stop. could a oil pump on the fritz cause it.
Jun 17, 2008 at 2:21 PM
DOCHAGERTY
  • 9,606 POSTS
Could be an oil related issue, does it have enough oil in it? Is it full of oil? Have you changed it recently?
Jun 17, 2008 at 2:29 PM
LEOGALLANT
  • 10 POSTS
i know my oil wasnt low. and i know it was clean because i change it befor every 3000 miles.
Jun 17, 2008 at 11:43 PM
