1992 Chevy Blazer Surging
154,156 MILES • 6 CYL • 4WD • AUTOMATIC
DALEB
The engine is surging at an idle, and does not want to take fuel. I have changed the spark plugs, wires, distributer, cap and rotor, map sensor, throttle positioning sensor and fuel filter. The engine surges and wants to die at an idle. At a stop you have to feather the gas and hold the brake. Once you take off it will stay running. Sometimes it takes it a while to come up to speed, other times it is fine. If I unhook the vacuum to the map sensor it idles fine. I have also changed the intake gasket and throttle body gaskets. What else can it be?
Jun 13, 2008 at 3:35 PM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:0c1535602e="daleb"]Engine Mechanical problem
1992 Chevy Blazer 6 cyl Four Wheel Drive Automatic 154156 miles
The engine is surging at an idle, and does not want to take fuel. I have changed the spark plugs, wires, distributer, cap and rotor, map sensor, throttle positioning sensor and fuel filter. The engine surges and wants to die at an idle. At a stop you have to feather the gas and hold the brake. Once you take off it will stay running. Sometimes it takes it a while to come up to speed, other times it is fine. If I unhook the vacuum to the map sensor it idles fine. I have also changed the intake gasket and throttle body gaskets. What else can it be?[/quote:0c1535602e]
Check for a Vacuum leak and/or Colapsed Vacuum Line.
Jun 14, 2008 at 4:08 AM
