I didn't really know what category this would fall under, but I'm sure it is the transfer case. It is stuck in 4-lo. When I try to shift it back into 2-wheel or any other, the shifter itself will shift, but it makes a grinding noise and won't shift out of 4-lo. So, my question is, is there a way to fix this problem, or should I go ahead and replace the transfer case? If I do need to completely replace it, will I need to replace the transmission? As far as driving and shifting 1st, 2nd, 3rd it does fine, but it won't come out of 4-lo, and as you know, you cannot drive one like that. Hope I explained everything ok. I just don't want to have to put more money into this than what I have to. It's actually in very good condition and has a brand new motor, so I'd like to get it fixed without it costing me a fortune.
Dec 22, 2008 at 7:51 AM
