1992 Chevy Blazer Starter problems
CHALLENGERBOY
  • 13 POSTS
Electrical problem
1992 Chevy Blazer 6 cyl Four Wheel Drive Automatic N/A miles
Brand new starter. will not turn ovar, i dissconected the battry and everytime i attempt to put the negative back on the battry it sparks and the starter tries to turn over. the battry is good. whats wrong with this starter? possibly the wire to the fuse box?
Jan 11, 2009 at 10:35 AM
BUDDYCRAIGG
  • 2,262 POSTS
either the starter is bad,
or you didn't wire something correctly.
Jan 30, 2021 at 1:47 AM
CHALLENGERBOY
  • 13 POSTS
everytime the starter clunks, as if it is trying to turn over. The starter is Brand new the wireing i didnt do. could the positave and negative be touching?
Jan 30, 2021 at 1:48 AM
BUDDYCRAIGG
  • 2,262 POSTS
i'm thinking more likely the positive battery cable is touching the small post that energizes the solenoid.
CHALLENGERBOY
  • 13 POSTS
probably its just difficult to get in there
BUDDYCRAIGG
  • 2,262 POSTS
[quote:469efe052c="challengerboy"]The same problem occured with the stock, original starter. Replaced it no difference, got the original starter checked at a shop they said it was fine. The spider fuel injector was replaced, along with spark plugs, wires, altenator, belt,and the air intake. The engine did not run when I bought the truck. The injector was out and broken at the time. Put a new charged battery in it and replaced connectors and and wires. When you turn the key the engine will crank for a few rotations, right before it starts it will make a very loud clunk! Then everytime you turn the key it makes the same clunk. If left for several min it will turn over just barely. This problem has been consistent through out replacemtent or cleaning of parts.[/quote:469efe052c]
i have to go out on a road call, but i'll take a look when i get back
BUDDYCRAIGG
  • 2,262 POSTS
I've had a rough night.
I'll check back on this thread as soon as i can.
BUDDYCRAIGG
  • 2,262 POSTS
maybe i misunderstood what you first said.
is the starter trying to turn over the engine when you connect the battery cables?
