1992 Chevy Blazer serpentine belts
220,000 MILES • 6 CYL • 2WD • AUTOMATIC
MICHAELKOTNIK
The belt slipped off after rain. I put belt back on but it wouldn't charge battery and engine ran hot. belt now is on but loose, how do I tighten it? Does it need replacement and is it within the range of a occasional mechanic?
Nov 8, 2008 at 12:37 AM
2CARPRO JACK
  • 11,533 POSTS
If it is loose, you have another problem. May be the tensioner has failed. Be sure it has spring tension and that the belt is routed properly. Something allowed it to come off in the first place, and that is the source problem
https://images.2carpros.com/forum/automotive_pictures/1639_28_1.jpg
Nov 8, 2008 at 12:48 AM
