1992 Chevy Blazer Problems
170,000 MILES • V8 • 4WD • AUTOMATIC
MEYEREJ
Hi. I have a 1992 chevy full size blazer that we have replaced the ECM module, air cleaner, cap & rotor, spark plugs & wires, fuel filter and I keep having problems alot of times when you first start it it will stall then it will start right up after that then when you go to drive it acts like it can't move then it will kick in and go and sometimes it runs just fine then sometimes when you back up it will stall and after you've been driving and shut it off then try to restart it again it acts like it doesn't want to start. We had a whole bunch of new stuff put on it and we are still having problems I don't know what to try next, can you help? Thanks
Mar 9, 2008 at 7:14 AM
RACEFAN966
  • 5,029 POSTS
Have you tested the fuel pressure? If you can get back to me with fuel pressure and we can go from there
Mar 16, 2016 at 1:49 AM
