1992 Chevy Blazer poor acceleration
189,000 MILES • 6 CYL • 4WD • AUTOMATIC
92BLAZER4X4
my 1992 s10 blazer 4x4 is accelerating very poorly... i tried going up a small hill the other day and no matter how far i pressed on the gas pedal it souldnt go over 20 mph... its very sluggish even when not going up hills.. takes a good while to get it up to 40 mph. ive replaced the distributor and still no go. But i have noticed a considerable amount of play in the throttle cable prob an inch to an inch and a half!!! could this be a problem???
Mar 7, 2010 at 9:56 AM
LEGITIMATE007
  • 5,121 POSTS
yes it could be the problem, I would also do wires and plugs, change air filter and fuel filter, then clean the throttle body
Mar 7, 2010 at 11:48 AM
92BLAZER4X4
[quote:b038f46ae7="legitimate007"]yes it could be the problem, I would also do wires and plugs, change air filter and fuel filter, then clean the throttle body[/quote:b038f46ae7]
those are all new also maybe like a couple of months or so... i did do a paper clip test and the only problem it gave me was a O2 sensor it said... but i didnt think that could be the problem.... the throttle body looked clean as well no build up or nothing
Mar 7, 2010 at 11:59 AM
LEGITIMATE007
  • 5,121 POSTS
well the engine may not be going into closed loop, if the oxygen sensor is faulty. without that, It will only run on a base set of parameters, you will not get anykind of performance out of it, so the oxygen sensor is a good start, I would address the mapp sensor too
Mar 7, 2010 at 12:05 PM
92BLAZER4X4
[quote:f6e09a4df3="legitimate007"]well the engine may not be going into closed loop, if the oxygen sensor is faulty. without that, It will only run on a base set of parameters, you will not get anykind of performance out of it, so the oxygen sensor is a good start, I would address the mapp sensor too[/quote:f6e09a4df3]
lol great!!! is there a way to test the o2 sensor without an expensive tool??? working on veeeery limited income :(
Mar 7, 2010 at 12:09 PM
LEGITIMATE007
  • 5,121 POSTS
I think I have something that will show you how in my reference material, hold on
Mar 7, 2010 at 10:15 PM
LEGITIMATE007
  • 5,121 POSTS
