1992 Chevy Blazer No Spark
DANIELMOORE
Electrical problem
1992 Chevy Blazer 6 cyl Four Wheel Drive Automatic
Good Morning, My girlfriends car would drive for awhile then die and have to sit for about 15 minutes then it would run again for a little longer but then die again. I changed the Oxy Sensor, Fuel Pump (In Tank), Coil, Distributor Cap, Rotor, Plug Wires, Plugs but now I'm not getting any spark at all. First I thought it was a fuel problem but No Spark. Please Help!!
Aug 3, 2009 at 1:56 AM
  • 110,246 POSTS
Make sure you are getting power to the coil. Also, check the ignition module. Let me know what you find.
Sep 2, 2009 at 2:48 AM
