1992 Chevy Blazer need help with getting the old starter ou
1992 CHEVROLET BLAZER
LOUISE55304
1992 Chevy Blazer 6 cyl Four Wheel Drive Automatic
My Son for the very first time is trying to get the old starter out of a 1992 chevy s10 blazer and he and his friend have not been able to get it out they said they got the bolts out of it but they still can't get it out. and I was wondering if you would be able to tell me what they could try that might help. Thank you very much I will wait for your answer.I don't have any money for a donation I am sorry.Please if you could still help that would be great.Thanks my email is emeralddiamond6@aol.com
Oct 21, 2010 at 12:49 AM
JIS001
  • 3,412 POSTS
STARTER MOTOR REPLACEMENT
Remove or Disconnect
Place the vehicle on a hoist.
1). Negative battery cable.
2). Brush end mounting bracket on the 2.5L engine starter motor.
3). Solenoid wiring. On the 4.3L, raise the vehicle halfway on the hoist, and reach through the right wheel well.
Raise the vehicle.
4 Wheel Drive Vehicles:
4). Four bolts on the skid plate (if equipped).
5). Skid plate (if equipped).
6). Bolts and the two brackets holding the brake line to the crossmember.
7). Crossmember (three bolts on each side).
8). Bracket holding the transmission fluid cooler lines to the flywheel housing, brace rod to the flywheel housing and/or the lower flywheel housing if necessary.
All Models:
9). Two bolts holding the starter to the engine.
10). Starter and the shim (if present).
Oct 21, 2010 at 1:29 AM
