I have a 92 S-10 blazer. With a 4.3 central port fuel injection motor. For some reason we can't get it to even start. At first when we got it, it ran but only for alittle while and then would die out like it was over heating or not getting any gas. So we replaced the water pump, thermostat, sending unit, fuel pump, gas lines, fuel filter, fuel pump relay and some other fuses and switches. But not we can't even get it to start. I was hoping you could tell me why. My brother in laws uncle said if you turn the key on and off like 5 to 10 times then the check engine light will blink so many time and you look it up. and however many times it blinks there is a certain code for that and that tells you what is wrong. I was wondering if that was true?
Nov 16, 2009 at 1:16 PM
