1992 Chevy Blazer locked up front end
114,000 MILES • 6 CYL • 4WD • AUTOMATIC
BEBO
first the problem started out with a bad shake in the front end almost like a wheel was out of balance. For a couple of days it went away. Then it came back two fold. It got to the point that it wasn't safe to drive on the freeway. I stopped to get gas and tied to go and the front end would rotate. It finally it let go and I got it home. I checked the brakes they VISUALLY look fine. so I went to drive it again and it ran fine for a while untill I stopped again. I locked up and I have not drove it since. I was wondering if it is inturnally in the brakes or isf it is drive train. Thanks for your help
Feb 16, 2008 at 6:24 AM
MASTERTECHTIM
  • 4,750 POSTS
jack up the front end and see if the wheels move at all. most likely it is a brake problem.
Feb 16, 2008 at 7:00 AM
