1992 Chevy Blazer leaking antifreeze from the tank
174,000 MILES • 4 CYL • 4WD • AUTOMATIC
KENNETH1970
my blazer is leaking antifreeze from the bottle the readatior is full but the bottle gets empty after a few trips also my oil lights are going up and down cant get a reading it does this when the blazer is in drive please tell me what to do thanks.
Jul 7, 2010 at 9:29 PM
HMAC300
  • 48,601 POSTS
you'll need another bottle, if you can't get one at a dealer an auto parts may have them or a junk yard. clean your grounds going to the engine for the lights, if it doesn't cure it have apro check it for a bad sensor or one of the wires worn through and touching ground...
Jul 8, 2010 at 11:03 AM
