1992 Chevy Blazer fuel pump
107,000 MILES • V8 • 4WD • AUTOMATIC
KWBSR64
drove sluggish (low power) to store. leaving store, would not start. not getting gas at carb. checked fuses at dash. all good except "crk". what's this for? turned ignition on and checked for voltage at fuel pump harness--none, 0 volts. HELP!
Feb 8, 2010 at 12:38 PM
HMAC300
  • 48,601 POSTS
replace the fuse first then if no voltage at pump see if your relay is bad, it is behind glove box. that may be bad. if not ou'll have a broken wire someplace.
Feb 9, 2010 at 10:34 AM
