1992 Chevy Blazer Advice on repair of fuel lines
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
BLAZING92
My 92 blazer was recently repaired after sitting for a couple years without maintenance. Worked great since for about three months when all of a sudden last week it wouldnt start. I took it to the local mechanic and he found that the fuel filter needed replacement. After alot of effort with old parts and dry rotted gas lines he managed to get the new fuel filter on. He told me that it ran shortly but wouldnt start a couple of minutes later. When i came in talk to him about the truck, his conclusion was to junk the truck due to its dry rotted lines and contaminated fuel (from sludge sitting in the tank and running the car low on gas) which was clogging the fuel filter. The main reason being that the cost to repair is probably more than what the car is worth.
One of the issues i have is if the cost is actually not worth it or not. Im assuming he saw the milage on the car at 170,000 miles but this is due to a new dash board.
Is a contaminated fuel tank with dry rotted lines an expensive fix? how much? and do you think that these two problems would be worth fixing if the car has under 80000 miles on it.
(does contaminated gas effect the cylinders or anything else that would do permenant damege)
Jun 10, 2010 at 4:07 PM
BMRFIXIT
  • 19,053 POSTS
Most likely mileage got nothing to do with it
visual check is what important here
as if fuel lines are rusty and corroded it will take a lot of hours and effort to replace and will end up costing more than the truck is worth ,dropping fuel tank with old rust fuel line , you will need to have the sending unit replace
old and dirt in fuel tank will cause a clogged fuel filter and or bad fuel pump
Jun 10, 2010 at 11:29 PM
BLAZING92
I did spend 1,000 dollars to replace the heater core, fuel pump, sending unit, and spider injectors. I wouldn't think it would effect the new equipment would it? I'm pretty sure the gas lines are in bad condition but the car ran fine with them untill I ran I low on gas and the sludge got mixed in with the gas. Is it worth going further and fixing it?
Jun 11, 2010 at 12:11 AM
BMRFIXIT
  • 19,053 POSTS
Your 1/2 way there
if the truck in good shape and you like to keep why stop
have it fixed
the hard job about the fuel line was done
it should nt be much more money to have the rest of the lines replaced
get another visual estimate
Jun 11, 2010 at 5:51 AM
