1991 Chevy Blazer starting problem
205,000 MILES • 6 CYL • 4WD • AUTOMATIC
EROWLEY
Example: It starts fine-no problem-then when I get in slow traffic it dies on me. When I try to restart, it will crank but won't start. If I wait a few minutes it will start right up with no problem. Then I can drive some more and the same thing will happen if I stop or cut it off. Please help, thanks
Mar 26, 2008 at 2:31 AM
  • 75,988 POSTS
Check the fuel pressure/idle air control valve and throttle position sensor to include the EGR valve-
Mar 26, 2008 at 2:54 AM
