1991 Chevy Blazer speedometer
LOVEHATER
Electrical problem
1991 Chevy Blazer 6 cyl Four Wheel Drive Automatic
I bought this blazer and the speedometer does not work, just wondering if you could give me some tips on what to check or how to fix it is a needle and not electronic thank you
Jun 8, 2009 at 2:42 PM
BILLYMAC
  • 2,204 POSTS
Hi it is not electronic ,but it has a spped sensor no cable. where the speed cable would be on the trans there is a plug and a round sensor about two inches around held in by one 10 mm bolt remove this . there is a plastic gear on the bottom of this sensor if it is sheered off replace with same color. if not replace the speed sensor. good luck billymac
Jun 10, 2009 at 12:59 PM
