1991 Chevy Blazer dies while driving and idling
198,485 MILES • 4 CYL • 2WD • AUTOMATIC
SHADOWSTRIKER
ok i got a brain teaser for you guys (or maybe not i suck with cars) im driving on the freeway fine, but once i get on the exit ramp and get to a red light for a few sec., the car rumbles and dies, i start it again just fine, then when i press down the accelerator normally, it barely moves, then jolts like i put it all the way down, then dies again. i start it up again just fine, does the same thing but doesnt die this time, i pull over to a gas station, checked all the fluids and they're ok. i start it up again and it does the same thing again, only now it dies again at another red light, so i start it up,, but at another red light i have one foot on the brake and one foot on the accelerator so that it keeps it from dying, so what am i lookin at here, is it the alternator, fuel filter, spark plugs or what?
Jan 25, 2008 at 7:08 PM
CPANDC
Had same problem with 91 blazer, not spider assembly or fuel pump etc. turned out to be distributor module ! Easy fix. That cured my problem, and was prob. the least exspensive. hope this helps you !
Feb 13, 2013 at 2:07 AM
