I just changed the clutch master cylinder, and i need to bleed the line but i dont know were the to go to bleed it.
May 22, 2008 at 4:57 AM
OBXAUTOMEDIC
✓Experienced Mechanic
Normally you should bleed it before you install it.
If you have some help you can bleed it at the slave cylinder on the tranny.
The brass looking thing on top is the bleeder vavle....
