Bleeding the clutch
1991 CHEVROLET BLAZER
280,000 MILES • 6 CYL • 2WD • MANUAL
GMALA
I just changed the clutch master cylinder, and i need to bleed the line but i dont know were the to go to bleed it.
May 22, 2008 at 4:57 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Normally you should bleed it before you install it. If you have some help you can bleed it at the slave cylinder on the tranny. The brass looking thing on top is the bleeder vavle....
https://images.2carpros.com/forum/automotive_pictures/188069_blazers10slave_1.jpg
Apr 9, 2021 at 12:56 PM
