The reserve bottle for antifreeze is broke in my truck?
135,704 MILES • V8 • 4WD • AUTOMATIC
TERRYNRAY81
My husband used to maintain the truck but since he is gone, I need some help. The reserve bottle for antifreeze is broke in my truck. I need to know if when I check the radiator for the level, must my engine be running or not.
Dec 11, 2007 at 6:17 PM
  • 75,988 POSTS
Before you start it remove the radiator cap-fill it with the proper antifreeze protection stop when its about 1 in from the opening, Now start the vehicle up observe the level if it goes down fill it again till it no longer takes it put cap back On -you're done.
Dec 12, 2007 at 5:42 AM
  • 55,649 POSTS
Here is a video that will help you check the coolant safety
https://youtu.be/GSE9skKnOgY?si=39tgGBA5QQicB5-F
Here is how to replace the coolant reservoir which would help the truck not overheat. Sorry to hear about your husband.
https://www.2carpros.com/articles/coolant-reservoir-replacement
Let us know if you need anything else.
Aug 13, 2024 at 6:29 AM
