HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Blazer
Fuel System
Fuel Pump
Fuse
SPONSORED LINKS
1990 Chevy Blazer Fuel pump
DEEBLASINGAME
MEMBER
1990 CHEVROLET BLAZER
6 CYL
4WD
AUTOMATIC
110,000 MILES
Thank, i'm not getting fire to the fuel pump, I have check the fuse, and replace ECM and also oil sending un.
Monday, April 20th, 2009 AT 6:47 PM
MECHANIC
Did you test the fuel pump relay?
SPONSORED LINKS
Monday, April 20th, 2009 AT 6:49 PM
DEEBLASINGAME
MEMBER
Yes, I install the fuel relay and also the fuel pump
Monday, April 20th, 2009 AT 7:23 PM
MECHANIC
Check for power at the orange wire on the fuel pump relay socket
Monday, April 20th, 2009 AT 9:34 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Fuse Content
Fuel Pump Fuse
Where Is The "fuel Pump Fuse" Location?
Asked by
wj2280
2 IMAGES
2000
CHEVROLET BLAZER
VIDEO
Fuel Pump Control Module Fuse Replacement
Instructional repair video
1996 Chevy Blazer Fuel Pump Fuse
Other Category Problem 1996 Chevy Blazer V6 Two Wheel Drive Automatic 189000 Miles On This Particular Vehicle Where Do You Find The...
Asked by
BRANDON KORNEGAY
1 ANSWER
1996
CHEVROLET BLAZER
1988 Chevy Blazer Fuel Pump Fuse
I Am Told The Fuel Pump Fuse Is Under The Hood But Cannot Find It. Where Is The Fuse Box Located. I Am A 70 Yr. Old Lady. Not Too Sharp As...
Asked by
peggym8
1 ANSWER
1988
CHEVROLET BLAZER
Chevy S10 Blazer, Fuel Pump Fuse
Ecm B Fuse Blows When I Try To Start The Blazer What Could This Be? The Fuel Pump Does Not Run. It's An 86 Chevy S10 Blazer With A 2.8l V6...
Asked by
lilcountrygal
1 ANSWER
2010
CHEVROLET BLAZER
1982 Chevy Blazer It Died
Engine Mechanical Problem 1982 Chevy Blazer My Blazer Started Puttering On Me And Then It Died. After My Husband Changed All The...
Asked by
pcsing8808
1982
CHEVROLET BLAZER
VIEW MORE
SPONSORED LINKS
How to Use a Test Light
Fuel Pump Replacement
Engine Not Starting
Online car repair manuals
