I drove my car to the store turned it off and when I returned it wouldn't start. It would turn over but it wouldn't crank still, I checked the injectors and there wasn't any gas coming out.I checked the main fuel line the goes in to the throttle body and there was no gas also.So I replaced the fuel pump and that got gas up to the throttle body but nothing out of the injectors,I'm not sure if there is a relay or a fuse for the injectors and if so I would like to check those before I replace the injectors.I would like the location of the fuse/Relay ?
Dec 17, 2007 at 11:13 AM
