1989 Chevy Blazer Forced shiftig, presusre valve.
20,000 MILES • V8 • 4WD • AUTOMATIC
COUNSELOR5150
It forces itself when shifting to 1st gear then after that it shifts alot easier. I also hear a vaccum line leak by the carb but cant find it.
Jul 16, 2008 at 12:58 PM
FEELGOOD71
  • 32 POSTS
try going to your local parts store and finding a can of non flamable brake parts cleaner.
spray a little in the area that you hear the leak from( the base of the carb) to pinpoint a vacuum leak you'll notice the engine will change sound once the vacuum leak is detected
odds are you'll find that you base gasket is causing the vacuum leak or a cracked hose
Jul 16, 2008 at 1:18 PM
