1988 Chevy Blazer Starting
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
FARLEYDP
I can jump start the car but get nothing after I've started & run it for awhile. Used battery tester & it comes back Ok, cleaned terminals but get no click, nothing if its not being jump started. Does this mean I need to change the alternator or could it be something else. Car runs well otherwise. Thanks for any help.
May 16, 2008 at 9:29 AM
MASTERTECHTIM
  • 4,750 POSTS
replace the baqttery terminal ends at the battery posts. you must be losing voltage there. you can cut them off and install universal ends for about 2 bucks. hope this helps
May 16, 2008 at 9:32 AM
