1988 Chevy Blazer Replaced pads, and calipers
232,000 MILES • 6 CYL • 4WD • AUTOMATIC
CARLIE75
I just replace my pads and calipers for my chevy, but still the breaks do not work well. Do I have to bleed the lines and if yes, How?
May 17, 2009 at 5:13 AM
KHLOW2008
  • 41,812 POSTS
Hi carlie75,
Thank you for the donation.
What is the problem that you are facing with the brakes?
Low brake pedal?
Inefficient braking?
When calipers are replaced, bleeding has to be done. You would require an assistant to pump the brake pedal and hold while you release the bleeder bolt at caliper.
Here are the procedures.
1. Pump brake pedal a few times.
2. Hold brake pedal.
3. Release the bleeder bolt at caliper. (Attach a hose to bleeder bolt to collect the brake fluid to prevent from splashing all over)
4. Retighten bleeder bolt.
5. Repeat Steps 3 and 4 till no air bubbles comes out.
Remember not to allow fluid level in master cylinder reservoir to go too low.
For bleeding, start with wheel nearest to master cylinder and move on to the next nearest with the farthest wheel last.
Mar 19, 2021 at 4:44 AM
CARLIE75
Yes the brean pedal goes to low and i don`t get enough breaking.
CARLIE75
I just went downstairs and did it and its working great now. Thank you very, very much.
KHLOW2008
  • 41,812 POSTS
Glad o be of service .
Thank you for using 2CarPros.
