1988 Chevy Blazer
1988 CHEVROLET BLAZER
STEVE1984
Shakes or Wobbles problem
1988 Chevy Blazer V8 Four Wheel Drive Automatic
As im driving down the road I notice that the rear of the truck will start vibrating quiet bad if I stay into it. It varies on the speed anywhere from 35 on up. Ive replaced the rear in the blazer as well as the two rear universals. I also replaced the pinion seal cause it was broke from the vibration and squirting out gear oil on the exaust. What else could it be
Mar 17, 2009 at 3:59 AM
RHALL77
  • 3,361 POSTS
did you check the condition of the tires and see if there is a broken belt or maybe out of balance
Mar 17, 2009 at 8:33 AM
