Yes my oil pressure gauge reads 80 all the time is this a bad ggauge or is it the oil pump?
Saturday, June 28th, 2008 AT 2:24 PM
MECHANIC
Could be the oil pump pressure relief valve not opening. Check the oil pressure with a mechanical gauge if normal -replace the oil pressure switch-if not engine bearings/oil pump etc-
