1987 Chevy Blazer not pumping gas to carb
250,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOBBYDANTE2222
hi guys..........
bobby here. i just replaced 3 freeze out plugs on rear of engine. took trans out and replaced plugs, V-6,2.8
87 s10 blazer 2 wheel drive. when reinstalled trans it would not start. lost ignition. finally put on a new body ground and got ign. back, But, now won't pump gas to throttle body! changed EMC module and still no gas. please help. car ran perfectly before changeing freeze plugs!!!!!!!!!
May 17, 2008 at 10:54 AM
  • 75,988 POSTS
You probably accidentally loosen a wire/harness going to the fuel tank-when you took out the tranny-recheck all wiring underneath
May 17, 2008 at 12:15 PM
