1987 Chevy Blazer My distribuer wont move
99,999 MILES • 6 CYL • 2WD • AUTOMATIC
BLACKPAINT1314
My buddy bought this s-10 blazer with the 2.8 liter engine thinking the timing was off. We tried to set the timing but we discovered the distributer will not move. The engine turns over and the distributer spins and fires just fine but we cant get the distributer to pull out or spin its stuck fast. Any information on why the distributer wont move will be helpful thanks
Jun 15, 2008 at 12:26 PM
MASTERTECHTIM
  • 4,750 POSTS
frozen rubber o ring on distributor shaft and sludge build up. try soaking with carb cleaner to loosen up. slightly tapping it back and forth with patience is all you can do. very common on this engine
Jun 15, 2008 at 12:29 PM
