1987 Chevy Blazer it will not start
14,674 MILES • 6 CYL • 4WD • MANUAL
VALERIE ALESHIRE
when u have the starter ingauged it will run when the starter is not engauged it will not run i have changed the coil /batter/pickupcoil/ and none of them seem to help
Feb 12, 2010 at 5:06 AM
  • 110,248 POSTS
If it runs in the start position and not in the run position, chances are either the ignition switch is bad or there is a problem with the PCM.
Has the check engine light ever come on?
Feb 17, 2010 at 3:10 AM
