1987 Chevy Blazer Gas and Oil
184,485 MILES • 6 CYL • 4WD • AUTOMATIC
TONYNBJ
Just picked it and was told at first oil pan gasket (OPG) was leaking and rear main seal (RMS) but then came back and they fixed the brake pressure switch never touched OPG or RMS still has small oil leak! Had the mainfold fixed that sounds great!
When I sit at a redlight engine sounds great
but when I take off the car chokes for gas?? after playing with pedal it takes off or sometimes it just stalls.
Fuel pump I think it is in the gas tank? or is it the fuel filter??
Any help would be very grateful!! <:O)
May 12, 2009 at 2:07 AM
RHALL77
  • 3,361 POSTS
test your fuel pressure and see what it is. you may have a fuel pump going bad. it is in the tank
May 12, 2009 at 7:42 AM
