1987 Chevy Blazer
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHRISTOPHERBLM26
when i step on the gas the blazer bearly goes i half to almost floor the pedel to go the engin has power but the tranny does not want to go
Mar 11, 2010 at 7:58 PM
  • 75,988 POSTS
Do you have a check engine light and when was your last tune-up-a badly needed tune-up will affect the transmission operation.
Sounds like the tranny is slipping severely-Get it pressure tested to find out more-if not you can do below
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 11, 2010 at 8:52 PM
