1986 Chevy Blazer Whistle/High Pitch Grinding
1986 CHEVROLET BLAZER
25,000 MILES • V8 • 4WD • AUTOMATIC
ASH.CADY
Fairly New sbc 350 and new turbo 400 trans. Inside k5 Blazer. Theres a slight wobble in the flywheel at an idle, which you feel when accelerating from a start. The noise started a month ago. From a cold motor, the noise starts after driving for 5 mins. Pitch of noise doesn't change from higher to lower rpm's though does fade in and out when coming to a stop. The noise is definatley coming from where the flywheel connects to the motor. I've sprayed a lubricant on this area and it changes the pitch of the grinding sound/whistle. Thankyou for your time.
Dec 16, 2009 at 3:38 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Have you removed cover and checked bolts are tight?Possible flex plate has cracked
Thanks for donate
Dec 17, 2009 at 1:54 AM
ASH.CADY
Well at the begginning I was skeptical about this website. You guys are amazing. You really nailed it on the head. I had a response in 24 hours. I'm going to Advance Auto Parts for a new nut and bolt and some loctite!!!! Thank you 2carpro!!
Dec 17, 2009 at 7:14 AM
DOCFIXIT
  • 18,828 POSTS
Your welcome glad it was not flex plate. Yes Loctite is good stuff
Dec 17, 2009 at 7:17 AM
