1986 Chevy Blazer how much to time a engine
XNOOKX
  • 1986 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 186,000 MILES
I was wandering how much it would cost 2 get my engine timed its a 2.8 liter v6 cause my blazer tries 2 start all the pullys turn but it wont start it trys to so can some 1 plz help me thank u
Saturday, April 18th, 2009 AT 4:22 PM
Do below to determine if its fuel or spark problem
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, April 18th, 2009 AT 5:32 PM
XNOOKX
  • 24 POSTS
I have taken out the spark plugs and clend them and that didnt help I have pourd alil gas n the carb but it did help what it does is when u turn the key it turns over and the pullys turn but it wont start the onjectors do spray out fuel
Saturday, April 18th, 2009 AT 6:30 PM
XNOOKX
  • 24 POSTS
This blazer has been siting 4 2 years
Saturday, April 18th, 2009 AT 6:41 PM
Did you check for spark? Check if you have it and then comeback
Saturday, April 18th, 2009 AT 6:43 PM
XNOOKX
  • 24 POSTS
How do u check for a spark
Nice to hear this stuffs-also check the fuel pressure
Saturday, April 18th, 2009 AT 6:44 PM
You need a professional help here-get someone that knows a little about cars-Do everrything I've mentioned on my 1st post and then get back with some results.
Saturday, April 18th, 2009 AT 6:48 PM
XNOOKX
  • 24 POSTS
K thanks
Saturday, April 18th, 2009 AT 6:49 PM
