How do you change a transfercase in a Chevy Blazer its a 1985.
Nov 1, 2009 at 1:50 PM
✓Experienced Mechanic
It's a lot of work. You need to remove the crossmember, the rear and front drive shaft, shifter linkage, any electrical connections, then unbolt it from the transmission.
