1985 Chevy Blazer Loss power around 20 MPH.
125,000 MILES • V8 • 4WD • AUTOMATIC
OATIKO
I lose power when my truck hits 25MPH. I step on the gas and it just revs higher and speed up really really slow. What could be wrong? Please help. Please.
Oct 15, 2010 at 8:53 PM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 15, 2010 at 9:48 PM
OATIKO
Thanks for the quick response. Im new to this whole thing but im eager to learn. I will look into what you suggested. What would be first thing to look at? Do you think my transmission is bad? It still drives smooth and there is no knocking noise coming from the transmission. It just doesnt go faster than 20 MPH I had to drive it home on second.gear at 15MPH. I hope its not the transmission.
Oct 16, 2010 at 7:01 AM
